KootK
- Oct 16, 2001
- 18,563
I'm designing a welded connection for an axially loaded member. A solid reference that I'm using says "in the design of welds connecting tension or compression members, the welds should be at least as strong as the members they connect"
I think that means that if the tensile capacity of my member is 100 k then the capacity of my connection should be 100 k. Others at my workplace think that the connection should be designed for the calculated load in the member and that the sentence above just means that the weld MATERIAL (ie. Fy & Fu) must be as strong as the base metal.
What are other people doing? Are you guys designing connections that develop the full capacity of the connected members??
