Bad Bridge Bearing Design Details 3
STrctPono
705
I need your guys' help in finding issues with these details. See attached. I have not been around long enough to have seen this design implemented in older concrete bridges or to see how it has performed. From what I hear from the older Engineers, corrosion, maintenance, and replacement have made this bearing type obsolete.
I have a list of issues and want to see if you guys have any more concerns.
 https://files.engineering.com/getfile.aspx?folder=168b23c9-d9a2-4f67-acc1-4d3b6068e136&file=Untitled.png
Thanks for the link.
Anode.... Check
Cathode..... Check
Return current path..... Check
Electrolyte...... Check
Moisture..... Check
bb,
Did you have problem to upload files to E-T? Quite a few people have the same problem, me included.
retired13 - I'm unable to upload files or pictures. I emailed the management and they said they're looking into it.
bb,
Thanks for confirmation. JoshPlum explained how he solved the problem at near the bottom of this thread Link. I might try it later.
