boundary fluxes in transient heat conduction problem 1
timex2002
5
hello everybody,
i would like to create a model in a heat conduction problem where I need to specifiy the heat flux on the model boundaries. The heat flux depends on the temperature on the boundary (actually even the T-gradient) so that the flux changes with the calculated temperature field.
How can this be modelled?
Thanks in advance and best regards!
A heat flux that varies with the surface temperature is called forced convection, where q/A=h(T-Ta). Arrange your heat flux into that form and use the *film option. ALternatively you could write a user subroutine.
