Hey guys,
just had a bit of a brain snap. Have been asked to go through and verify some calculations from 1992 and have got to a part where he calculated the brake deceleration rate. Can't seem to figure out how he went about it, if someone could help me that would be great.
Here is the information given
Brake Torque = 295.1002 kNm
Drum Speed at brake tip = 3.68 m/s
Drum diameter at rope = 3400.8 mm
total system inertia at drum = 465109 Kg m2
Rope load at drum = 114.9 kN
brake path width = 203mm
brake path thickness = 38.1 mm
brake path length = 1438 mm
deceleration rate at brake = ?
deceleration rate at drum = ?
