Calculate Beam Deflection Using Spreadsheets
Bozzo
4
I have created a simply supported beam spreadsheet to design wood beams. I have figured out that with the use of Superposition I can combine the affects of each load to determine the total affect on the beam. I have used this principle to determine the shear and moment at every 100th of a foot on the beam. Now that I know the moment at every point on the beam is there an easy way to calculate the deflection using the Moment-Area Method or Conjugate Beam Method?
I need something that will give the deflection at any point along the beam for any load case.
Can I Double Integrate the moment at each point on the beam to determine the slope and deflection?
Hi Bozzo
You can use any of the methods you mention however the method you choose should be one that suits your requirements best ie:- "the moment area method" is useful when you require a slope or deflection at a single point with reference to another point having zero slope.
The direct intergration method is useful when the bending moment equation is valid across the whole length of the beam.
I don't think you will find a single method suited for all loading conditions and you may have to choose a method as stated earlier.
Several other methods to mention which I have used in the past are "step functons","Macaulay's method","Castigliano" and "Srain Energy"
regards
desertfox
Hi Bozzo,
You already have the bending moments at every 100th of a foot, so why not continue along the same lines with the method of `virtual work`.
If you are not familiar with this method -
Apply a unit load (1.0 with no units) to the the beam at the position where the deflection is required and calculate the `unit bending moments` at every 100th of a foot.
Then at each 100th of a foot, multiply the two bending moment values to give a third value (lb.in^2) at each position. Calculate the area under the new set of values (lb.in^3) and divide by EI (lb.in^2) to give the deflection (in) at the point of `unit load`. Repeat the procedure at each point along the beam to find the deflection at each 100th of a foot.
The formula is simply - deflection = M.m.dx/EI
The calculations are repetitive, but should be easily programmable into a spreadsheet!
Neilmo
Thanks everyone, especially Neilmo. The sheet is working great.
