they have both a hp from Trap speed and a more sophisticated "drag strip simulator". While I haven't dynoed my car, the "drag strip simulator" gave surprisingly accurate results when I compared it to my timeslips and used the stock hp from my nearly stock motor. Worth a look.
time to whip out the old "dream wheel " from the 70's....
surprisingly close. Isky, Bell Auto Parts, Automark all printed them.
at 2200 pounds and 112 mph it shows 260 hp.
The et compared to the mph shows to me I think that this is a result of the front wheel drive....the car might have the potential...at that mph at least, to have a lot better 60 foot times and run in the 11's even with FWD.
The mph is what the clocks show...scepticism aside...but are the clocks correct and was that just on one run or a more 'realistic" best of 2 or 3?
i've used this formula with good success. If the car is properly geared (finishing the 1/4 mile 3-400 rpms past hp peak)you should be able to get a fairly accurate result using this:
hp= (mph x .00426) cubed x weight
this would result to about 350 hp
i like this formula because it doesn't take into account reaction time or e.t. which vary much more than mph does
if you make a disasterous run.
