VanBurenSoilGuy
- May 18, 2010
- 15
I am proposing to construct a temporary crossing across a wide ditch using 12" x 12" oak timbers. Four 20' long timbers are bolted together, similar to a crane mat. I am proposing to place a set of them from top of bank to top of bank to form a 8' wide deck. The load will be a 35,000 lbs 3 axle earth moving vehicle. How would I calculate if the timbers would hold up to this type of loading? Also, what are some important factors I would need to consider?
Thank you in advance.
