MadMango
- May 1, 2001
- 6,992
I don't think this is defined in any standard, so I wanted to check here. I have a machined hole that requires a flat bottom, but I do not feel a section view is required for it. In the past I have used the counter-bore symbol to define a flat-bottomed hole without trouble.
My last employer/vendors had no problem with this method of call-out, QA/vendors at my current location are questioning this practice. Any suggestions?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of Eng-Tips Forums?
