Can I Add MMB to Datum A to get Datum shift to Facilitate Bigger Diameter(Datum C) during Assembly
2020Learner
Automotive
Jun 27, 2021
19
0
0
HK
Hello Team,
I have a question on the attached picture. CAn I make Datum "A"(Dai. 40) as MMB to get DAtum Shift to facilitate Assembly of bigger Diameter (Dia.90) with counterpart during Assembly?. This is Sheet Metal part.
Evan Janeshewski,
Thank you for the reply.
That means, My Gauge pin at MMB at Datum A is Dia39(VC= 40-0.5-0.5= 39), When this diameter reaches worst case deviation of minimum material boundary of DIa 41 (40+0.5+0.5= 41mm), Radially i will get 1mm DAtum shift at Datum A all around so that Bigger Dai.90mm(Datum C) will be flexible to assemble with Counterpart.
Is my calculation is correct?
2020Learner
