Can UG expressions be Hidden
rk2007
Automotive
Oct 8, 2007
6
Is there any way to hide expression rules. I want that others should see only the values of the expression and not the rule.
Any help is highly aapreciated.
rk,
Perhaps what you really want to do is either to create a program or pass calculated values back and forwards using a spreadsheet. The tool you have asked about is set up to be intentionally transparent so that subsequent users can work with one another's data. If we knew why you wanted to hide the expression formulas then maybe we can point you in the right direction.
Hudson
thanks Mr. Hudson and MR. john for ur feed back.
