TJW
- Jul 10, 1999
- 33
Does anyone have a good source for design information for a capstan as used in a winch application (I'm not designing a tape recorder which seems to be the most documented use of a capstan!)
The system in question would have a specific line pull on the haul line, which is then wrapped some specified number of turns around a capstan and then to a winch drum which takes up the slack under a reduced tension (due to the capstan).
I'm looking to determine the line pull on both sides of the capstan (based on the number of wraps), and the horsepower requirement of the capstan.
TW
TW
