I have been looking for a light wall carbon steel tube material that would be acceptable for use as a shell on ASME pressure vessels. Anyone know of a common material, readily available in 8", 10", 12", 14", 16", 18"?
Try SA-334. Most (all?) other tube specs approved for Sect VIII-1 service are for heat exchangers, boilers, heaters, etc, and are not available in larger sizes (not, at least, per the specs in ASME Section II Part A).
SA-334 addresses seamless and welded carbon and alloy steel tubes for low temperature service. But the low temp aspect shouldn't be a problem.
Story,
The ASME BPVC has specified the calculation of minimum wall thickness of various materials, for vessels designed in accordance with this code, hence the "light" wall tubing is subject of this minimum wall thickness.
The ASME VIII code has established the clear criteria for pressure vessel definition in the "Introduction" chapter, clause U-1. The use of any material under the ASME jurisdiction is restricted to the materials listed in ASME Sec. II, Table D (others may be used, under given conditions). There are many grades of carbon steel piping and tubing which may fall under your requirements, taking in account your application, corrosion requirements, pressure and temperature, etc..
Please read first the relevant ASME VIII Clauses U-1 ..U-3, it will help to clarify your questions and our answers.
cheers,
gr2vessels
Thank all of you for your contributions to my original submission. I should have been more specific.
I am looking for 8" od thru 20" od light wall carbon steel tubing (not pipe) to be used as shells on air receiver tanks. The material SA-334 exists in the code, but my pipe supplier cannot source it in Canada through his normal avenues.
Can anyone suggest a source for this material in the sizes listed? or perhaps an alternate material more readily available.
The most common material I have seen used on air recievers is SA-414 G. The allowables are considerably higher than SA-334 so any difference in strength may make up for the fact that there needs to be a long seam and possibly a lower efficiency.
When you say "light walled" what is your reference point?
In Alberta, std wall in A 106 Gr B is considered minimum and it is usually easy to find (depends on quantity).
