CG of the model in FEMAP
ttaannggeenntt
Aerospace
Mar 20, 2017
3
Hi All,
I am trying to find the CG of my model in FEMAP in order to apply a mass element which will represent some components of my model. The problem is with Tools> Mass Properties > Solid Properties I am prompted to choose only one geometry. How can I get the CG of my model without meshing the whole model? Do I have to get the CG in cad and just create a node at the CG instead or can I do it all in FEMAP?
Thanks!
"How can I get the CG of my model without meshing the whole model?" not sure you can ... meshing is how Femap understands the structure, and is where you apply density and weight.
Sure you can go through AutoCad to get the CG ... I guess that'd be a volume CG since I don't think AutoCad understands weight.
Else run Femap with three supports and determine the CG from the results.
Ah alright thank you for the reply. Ill probably go through CAD.
does Cad understand the weight of your assembly ?
This is something that can be done in Femap via API; see the code below, paste it into your Femap API programming window and try it.
Sub Main
Dim App As femap.model
Set App = GetObject(,"femap.model")
Dim sol As femap.Solid
Set sol = App.feSolid
Dim solset As femap.Set
Set solset = App.feSet
Dim area As Double
Dim vol As Double
Dim cg As Variant
Dim Inetia As Variant
Dim density As Double
solset.Select (FT_SOLID, True, "Select Solids for Mass Properties")
App.feGetReal ("Enter Density", 1E-15, 1E+16, density)
SolidID = solset.First
While SolidID > 0
sol.Get (SolidID)
sol.MassProp (area, vol, cg, inertia)
CGXw = cg(0)
CGYw = cg(1)
CGZw = cg(2)
currentmass = vol*density
mass = currentmass + mass
cgxT = (cgxw*currentmass) + cgxT
cgyT = (cgyw*currentmass) + cgyT
cgzT = (cgzw*currentmass) + cgzT
SolidID = solset.Next
Wend
cgx =(cgxT/mass)
cgy =(cgyT/mass)
cgz =(cgzT/mass)
App.feAppMessage (FCM_NORMAL, "The total Mass of the selected solids is "+ mass+".")
App.feAppMessage (FCM_NORMAL, "Center of Gravity: X = "+ Format (cgx, "0.#####")+", Y = "+Format (cgy, "0.#####")+", Z = "+Format (cgz, "0.#####")+"." )
End Sub
Joe
