Adamian
- May 8, 2010
- 31
A previously DIV-88 retrofitted West Los Angeles building was undergoing a change of use that would require an occupant load greater than 100. The building was previously thought to have URM walls. However, the test by a specialized company revealed that the brick wall has reinforcement bars at 12’’ horizontal and 14’’ vertical, 5’’ deep from the exterior face of the wall. In addition, a 5’’ thick layer of high-strength concert (no rebars) is applied on the inside face of the 13’’ thick brick wall. Questions:
1. Does this new discovery change the URM wall to a different structure?
2. If yes, does the DIV-88 retrofit completed in 1990 become absolute?
If not, is any new retrofitting required to the building to allow an occupant load greater than 100?
