Aleeeex
- Aug 14, 2020
- 42
Hi Guys,
I'm considering how to support the removal of the chimney on the ground floor while also providing a steel beam to support the stack above. I ran preliminary calculations with the 2x beams running parallel to the party wall underneath the chimney, but I am not satisfied with this option because there is an opening on one side and there is not enough room to support the beam.
However, I believe that with the attached option, one beam must pass through the bathroom. Please let me know if you have any other suggestions.
