I have a server computer which contains three cooling fans. The fans' speed is controlled by firmware, but even the lowest speed is very loud, even though all the internal components are always very cool to the touch.
So, I want to find some way to reduce the noise level. When I removed one of the fans, the machine's BIOS objected loudly, refusing to boot. So then I took a spare fan and hacked off the rotor housing and connected it, but this seemed to screw up the feedback signal, and the fan's "failed" light came on and the BIOS objected again. Another option would be to simply cut off the rotor blades, but they are very difficult to get at with ordinary tools.
The next thing I would like to try is to construct a simple circuit which would simulate the presence of a fan. There are three connections; 0V, supply (presumably variable voltage), and feedback. I'm not an electronics engineer, but I do have some experience of amateur electronics and can build a simple circuit from a schematic.
So, can anybody point me in the direction of a suitable circuit or discussion of the technology involved, or provide helpful hints of any description?
Thanks very much.
Tony.
Thanks very much.
Tony.
