MarcinGIT
- Mar 7, 2024
- 2
I'm Looking for support for CNCHK5 machine. Please HELP!!!!!! Problem with vertical blade, when we speed up the blade, the blade brake.
The problem is with vertical blade. when I START running the blade on regular starting speed, everything is ok, but when I want to speed it up, blade brake.
I took off both servos motor and I noticed that the one gearbox does not rotate as smoothly as the other one
