CNODE to Model Displacements?
JackBolt
17
Hello all,
I want to model an existing pipe in a piperack and use CNODES to impart a 3" vertical upward deflection to simulate lifting a portion of the pipe with come-alongs. There are no thermal stresses being considered, just trying to see what stresses are induced by lifting a portion of the pipe to make some repairs. The geometry at the point of consideration is a 4" teeing into an 8" which also has a 12" branch. I need to lift the 4" portion of the line 3 inches and want to make sure I do not overstress any portion of the line(s). My question: Is CNODES the best way to model this 3" vertical displacement? If not, please suggest alternatives.
Thanks in advance,
You really don't have to use CNODES, you can just displace the pipe nodes upward 3".
Richard Ay
Intergraph CAS
Just a point of order. Quote " a 4" teeing into an 8" which also has a 12" branch". I understand a 4" teeing into an 8" but how can the 8" or the 4" have a 12" branch???
richay - If you model the nodes 3 inches upward, doesn't that just simulate the pipe being 3 inches higher relative to the ground? How would that capture the induced deflection stresses? Or, maybe I am misunderstanding your suggestion of "...just displace the pipe nodes upward..."
DSB123 - yeah I knew someone would have a problem with the wording of my post. Remember, I am a structural guy not a pipe guy. There is a reducing tee which connects the 4" to the 8" which explains the 4" line. There is also another tee which is an 8"x8"x8"; however, the branch portion I was talking about is further downstream where the 8" swedges up to a 12"...I was (incorrectly) calling that a 12" branch.
I meant:
- check the checkbox for "imposed displacements"
- in the resulting dialog, specify the node number and the magnitude of the desired displacement in the appropriate DOFs.
- later, when setting up load cases, apply the defined displacement vector in the desired load cases.
Richard Ay
Intergraph CAS
