Sawsan311
Chemical
- Jun 21, 2019
- 301
Dear All,
As part of the design of wet CO2 compressors (MW 43) with suction pressure = 0.3 barg while discharge pressure at last stage is 40 barg. I have gone through the possible control mean with a a variable IGV against performance control through motor speed variation. I understand that IGV performance curve matches with the 100% speed curve of a VSD machine, however, I have a technical concern on its robustness to cover the system resistance curve for the pipeline application. Additionally, IGV cause more drooping of the efficiency curves unlike VSD which maintains flatter efficiency at the different speeds.
I need your views on the advantages and disadvantages of IGV against VSD motor control specially for such a heavy gas CO2 application.
