To BAretired (sponton and others). This is continuation from thread because of word wrapping problem there.
BA you stated before when we were computing for pure axial load that "Note: The above calculation assumes uniform strain throughout the column. If a transformed section is used, the centroid of the combined section would shift toward the concrete portion. That would cause bending stress in addition to axial, so the condition is likely going to be worse than calculated"
I'm interested in how to exactly compute for the bending stress due to the void. In the above figure. Even without moments and pure axial load. You stated " If a column is hinged top and bottom and compressed with axial load P, the stress is uniform at every cross section, namely P/A.
If a rectangular notch is cut out of the left side of the column at mid-height, the centroid moves to the right at the notch. The axial load falls to the left of the centroid and the notched section will move right relative to the hinged ends.
If the notch had been filled with material with low E, the behavior will be similar, but the centroid will not shift as far so the filled notch will not move as far to the right as the unfilled notch because the fill is carrying some stress but not as much as the concrete.
If axial stress exceeds bending stress, there is no tension on any part of the cross section, simply variable compression with maximum value on the left and minimum on the right."
BA, how would the bending stress equilibrate.. there is more compression with maximum value on left and minimum on centroid. Until what moment will it steady. How would point B in the figure with concrete edge (before epoxy void) behave in the equilibrium?
Thanks.
Thanks.
