Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
wag2483 said:while the pin/moment direction has k=0.7.
AskTooMich said:Moment frame is 2.0
AsktooMuch said:"Be careful. There is no upper limit on K for a sway uninhibited mode. It could exceed 2.0. probably won't, but it could. "
You are way overthinking this. We are talking about the OP post and it's clearly a 2.0 in E-W direction. I already mentioned there is a graph to calculate this exactly in real projects where you know the member sizes.
