marshell
- Jun 6, 2003
- 63
Is it ok to combine a Composite hole location with a Bidirectional call out? I want to allow the PLTZF to have a relatively large X movement, with a smaller Y movement, while at the same time I would like to limit the FRTZH and have it be a diametric control. I could find no examples in Y14.5, nor anything saying I could or could not combine the 2 methods. If it would be cleaner to remove the diameter off the FRTZH and have it be a square zone, I could do that also.
I have included an attachment, because I am sure I have not explained what I am trying to do in a clear way, and a picture is worth a thousand words.
[URL unfurl="true"]http://files.engineering.com/getfile.aspx?folder=babed142-e632-42e5-b7a0-7b2ef3701245&file=Composite-Bidirectional.JPG[/url]
Thank you.
Thank you.
