CarbonWerkes
New member
Hello
I have an application where I will need to employ 8-10 low-side mosfets for simple DC power switching- replacing some conventional mechanical switches in an automotive environment. The expected current is 20A at 12V max. Id like to know if anyone has any practical experience with physically interfacing mosfets (Dpak, maybe T0220) to the low side of the switched load. Specifically, I dont think I can implement a conventional through-hole type edge connector (Phoenix, Molex etc), as I run into trace width minimums at the interface to the mounting hole. Is it resonable to just mount a connection tab very near the Drain on each low side switch, perhaps even soldered to the FET tab in question, and then just tie the Source side of the Fets to some bus bar to ground? This seems plausible, but with all things automotive, vibration and temp swings tends to throw a monkey in the works...
R
R
