I have a small copper bar (.5"x.75"x6") that is used for water flow, and get soldered to small tubes, almost like a main water valve that distributes water to smaller tubes along the copper bar. The part is originally made from C110 copper bar. A manufacturer is quoting to make it out of C11000 instead of C110. Based on my research, the materials seem almost identical from what I can tell. Any recommendations to these two copper alloys and if the alternate material option will suffice?
Thanks!
Thanks!
