Hi everyone,
I'm looking after a propylene glycol heating system.
There has been corrosion issues with the system since installation, particularly for the aluminium boilers. I had taken samples of the system and measured a ph of 8.5 and chlorides as high as 150ppm. No other contaminants i.e. calcium, magnesium, sulphates were out of recommended range
Can someone suggest what I can do to remove the chlorides? I had flushed the system out last year and put in a new batch which I also had measured and found little to no chlorides or contaminants, I'm not sure how it developed in the system. Also what reactions does the presence of chloride induce? especially ones that would cause the pH to rise. The glycol in the system has also turned yellow colour from initially being clear, with a strong chemical smell to it.
Thank you.
Thank you.
