Corten Temperature Properties 1
weissman530
4
Does someone have or can you direct me to the maximum temperature limits for various grades of Corten Steel?
(A242, A588, A871, A852)
Corten is in essence a variation of high strength-low alloy construction grade steels with additional Cu to enhance corrosion resistance and would not normally be considered for elevated temperature applications for the following reason:
The mechanical properties of the high-strength low-alloy steels depend on their hot rolled condition. These steels are not further heat treated except for annealing, normalizing or stress relieving, applied as required to facilitate cold forming. The heat treated grades depend on either precipitation hardening or quenching and tempering for development of mechanical properties. Ref: 8th Ed Metals Handbook Vol. 1 p87.
In other words, if you heat these steels the properties are going to change. However, there could be data on what these properties are at elevated temperatures but it does not seem likely given the above excerpt and having seen how these alloys are typically applied where min yield of about 50,000 psi is required.
If you are only looking at a few hundred degrees F, probably no problem. Otherwise you should probably be looking for a heat resisting alloy.
hope this helps,
Leonard Jesus is the WAY
Normal Temperature range is 200-400 degrees F with monthly excursions to 600-900 degrees F for short periods of time. Relatively light guage A242 used as a support for a heat exchange media.
weissman530
Looks like TVP's lead worked for you. Did you get this info from the USS website? Obviously I am surprized based on what I thought I knew.
Yes. I did, Thanks. Basically the answer was that Corten should not be used above 800F. The strength falls off drastically at that point.
