  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Create Axis 2
rossly
Automotive
Sep 22, 2003
115
0
0
Here is another of my "Did it in UG" questions.
Can you create an axis that is normal to your screen?
Ross Parpart
Product Design Engineer
UGS NX3/CATIA V5R15
Create it initially or have it normal at all times? I mean, you can spin your model around and then it's not normal anymore.
Please elaborate.
Fighter Pilot
Manufacturing Engineer
Here is where I would use it. If I am looking at my data and need to figure out a die draw that is off grid line and my moving the rotating the data I can get what I want for a draw angle/direction. Then I would want to create an axis that is normal to the screen. This can be done with a plane > Equation option, just wanting it for an axis.
Hope this explains it...
Rossly,
for your approximate die draw, create axis system, Right click in the z axis -- create plane -- equation and there you are. Note X axis and y axis should be set to No Selection.
Derek
