Create different bodies with Design Modeller
davidrdguez
59
Hi there,
I want to create a simple geometry with the Design Modeller for an axisymmetric analysis.
I create different sketches, then surfaces from each sketch.
The problem is in the end I only get one body (and one part), so I can't give different properties to each surface.
Does anyone know how to separate them?
Thank you
regards,
David
David,
You might try:
After creating first surface from sketch, use the freeze button to avoid next surface being merged to the first one.
Hi there,
I add the surface as frozen (and not add material) and it works
thank you!
