Create Rod Element
VH88
Aerospace
Feb 20, 2020
9
Can someone please tell me why I have the return code of 8, which is FE_BAD_TYPE, when executing "Element.PutAllArray"? What did I do wrong here? The script below prompts user to select nodes and a rod property, then create rod elements.
Sub Main
Dim App as femap.model
Set App = feFemap()
Dim NodeList As femap.SortSet
Set NodeList = App.feSort
Dim Element As femap.Elem
Set Element = App.feElem
Dim entID, propID, elemTYPE, topology, layer, color, formulation, orient, offset, release, orientSET, orientID, connectTYPE, connectSEG As Variant
Dim Nodes (1) As Long
Dim pset As femap.Set
Set pset = App.feSet
Dim pid As Long
rc = NodeList.Select(FT_NODE, False, "Select Nodes")
rc = pset.SelectID (FT_PROP, "Select a Rod Property", pid)
While NodeList.Next()
Nodes (0) = NodeList.Current
Nodes (1) = NodeList.Next
entID = Element.NextEmptyID
propID = pid
elemTYPE = 1
topology = 0
layer = 1
color = 124
formulation = 0
orient = 0
offset = 0
release = 0
orientSET = 0
orientID = 0
connectTYPE = 0
connectSEG = 0
rc = Element.PutAllArray( 1, entID, propID, elemTYPE, topology, layer, color, _
formulation, orient, offset, release, orientSET, orientID, Nodes, connectTYPE, connectSEG )
App.feViewRegenerate( 0 )
Wend
End Sub
