  • Congratulations IFRs on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
curve creation question
jnikolauk
Automotive
Jul 18, 2011
145
Is there a (quick) way to generate a line along a surface at the points closest to a non intersecting plane?
Attached is a more general solution. I first create a datum plane offset from the plane you require the curve(s) from. The datum plane is located so as to intersect the face of interest. Next create a section curve. Then move the datum plane until you get as close as you need to the desired curve. Note that for a face with no inflextion but convex in both directions then the minimum distance is a point. For a surface with inflection you could get multiple curves.
Attached are a part file and a jpeg image.
Frank Swinkels
 http://files.engineering.com/getfile.aspx?folder=3af102fb-13bc-413b-bef2-4bd91d65ae15&file=curve_closest_to_plane_fbs.prt
