Hi All,
Is there any standard or guideline which indicates or gives procedure to calculate D/t ratio of steel pipe from structural stability point of view.I have a 60" pipe having wall thickness 0.354",pressure is only 10 psig,support span is 100ft.
Thickness is alright for 10 psig pressure.But is this pipe going to be stable when erected on pipe supports at 10 m height over a length of 100 meter.
