Not sure if I need to post a picture so I will try to describe this as best as I can.
I have a hole pattern in a stamping located with a positional callout (MMC) to three datums:
A = plane, surface of part
B = central pilot diameter (MMC)
C = hole, not contained in hole pattern (MMC)
When the stamped part is used to produce the final part, a rivet is orbitally formed into datum C. After all other parts are added to finalize the assembly, the rivet cannot be reached to use as a datum feature.
So in the assembly I have specified the position relative to two datums (A and B as defined above).
The other engineer in the group thinks that I have to have a third datum to "clock" the hole pattern. In general I think she is correct, otherwise the pattern can technically rotate around datum B. However the higher level drawing does prevent this to a certain extent. The problem is that I do not really have a valid feature that I can use for a tertiary datum that makes functional sense (I don't want to pick a bogus datum just for the sake of doing so).
Any ideas (do I really need a tertiary datum)? Thanks!
