Datum feature and Datum feature reference frame.
TOOLS4FOOLS
Aerospace
Oct 20, 2006
19
Please see attachment and comment your verified thoughts.
Let's get this out of the way, first...
ASME Y14.5-2009 said:
1.3.13 Datum
datum: a theoretically exact point, axis, line, plane, or
combination thereof derived from the theoretical datum
feature simulator.
1.3.16 Datum Feature
datum feature: a feature that is identified with either a
datum feature symbol or a datum target symbol.
1.3.17 Datum Feature Simulator
datum feature simulator: encompasses two types: theoretical
and physical. See paras. 1.3.17.1 and 1.3.17.2.
1.3.19 Datum, Simulated
datum, simulated: a point, axis, line, or plane (or combination
thereof) coincident with or derived from processing
or inspection equipment, such as the following
simulators: a surface plate, a gage surface, a mandrel, or
mathematical simulation. See para. 4.6.
Now.. back to my response:
"The drafting requirements manual 11th edition:"
I don't know what manual you're talking about.
As with Belanger and others, we mainly speak and cite directly regarding ASME Y14.5-xxxx depending on the one at hand. Your drawing references 2009, so that's the one referenced. Directly.
I personally don't understand your question in the attachment. Sentence fragments are too fragmented for me to conclude your point, and you use somewhat-slang terms that aren't completely familiar to me.
You can find many examples in the 2009 standard which have a FCF with a DRF containing self-referential Datum Feature.
The third datum, as others echoed, is unnecessary, as shown in Fig 4-8 suggested by Belanger. I don't think that's even a debatable point. You mention "truly restricting the six degrees of freedom" but, for emphasis, this is not a requirement. In some cases it may not even change anything by calling it out in the DRF. So I suppose I would not agree that it applies as a "3rd reference" unless you make it so. The wisdom of making it so... that is debatable.
As for 'best practices' - I would start not with "dimensioning to the datum plane" but rather your use of a circular hole pattern, but not calling out the diameter of it, and also lacking basic dimensions to the 12, 3, 6, and 9 o'clock holes. You locate only 4 holes, the way it is dimensioned currently.
