par1
Automotive
- Oct 11, 2004
- 134
I have one dwg which has 3 holes on the plate.
In a dwg, they defined a
datum point A1, A2,A3 as the centre point of the hole.
datum B is defined as centre plane of one of the hole
In a feature controlled frame for datum B
block 1 has 0.5 positional tolerance with 0.5 MMC
block 2 has mentioned datum A
Datum C defined as centre plane of one of the hole & there is attached Featured controlled frame
blcok 1 (In feature control frame) has 0.5 MMC of positional tolerance
In block 2 there is only mentioned datum A
block 3 has datume B with MMC condition
Now my question is
1, There is nothing like datum A defined but only the datum points A1, A2, A3 so how could i define the datum B& datum C using reference from datum A?
2. While defining the datum C ; what does the mean of block 3 in feature controlled frame " datume B with MMC condition" ( I think it is a datum shift - but not sure about the understanding or how to calculate tolerance stack)
could you explain me in detail.
Thank you very much in advance,
Now my question is
