bxbzq
- Dec 28, 2011
- 281
I've realized the most difficult part of applying GD&T is datum system establishment.
I'm working on a part that is huge in size and has thousands of features on it. It is an air flow inlet part. The part has outer housing and inner housing. The air flows between outer housing and inner housing. The part assembles with a cylinder to its right, a bearing inside the inner housing. There are two Supports to support the part. A rotor shaft goes in bearing and on the part there are 3 grooves for 3 rings which are coaxial with rotor shaft. Detailed description please see attached sketch.
Currently in our drawing there are just 2 datum features are specified which are horizontal and vertical flange. I think there is room to improve the existing datum system of the part.
Comments, suggestions, ideas are appreciated.
