Yuyu28
New member
- Sep 6, 2019
- 15
I have the following drawing of the grooves on a shaft that hold retainer rings. I know it is not fully constrained, but that is not relevant to the question.
Context:
a) FUNCTION: The shaft fits with clearance into two holes to constrain two other parts radially. The axial movement is constrained by the retainer rings.
b) The tolerances specified are given by the retainer ring specifications, and the rest are controlled by general tolerances.
c) The concentricity tolerance is important only between the groove and the far-side/shorter cylindrical FOS of the shaft, not between the groove and the longer FOS.
d) The shaft length is 210mm.
e) We are working with ISO 1101:2012.
My questions are:
1) Is it valid to define datum A in a detail view that has a 2X note under it? Would that mean that there is another datum (A'? B?) implied at the other end of the shaft, or would that require a note like "EACH" or "2X" under the datum feature symbol?
2) If there is not a second "implied" datum, how would one unambiguously control the concentricity of the groove on the other side? Would it be necessary to create a second detail view on that side, defining datum feature B there? I thought of removing the 2X from the detail view label and putting it on each of the dimensions, but that can lead to controlling one groove's concentricity w.r.t. the FOS on the other side.
EDIT: added function for clarification.
Context:
My questions are:
