dik
- Apr 13, 2001
- 26,067
Was it removed before an investigation... seems a little hasty.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
But why now?
TugBoatEng said:We do know the top plate is very thin
TugboatEng said:That doesn't change my weld distortion comments.
Alistair Heaton said:I think we have different usage of the "field" weld. Basically any weld that's not done in a fabrication shop with QA and certified welding supplies etc is deemed field.
Alistair_Heaton said:Was trying to think of anything similar scale in UK or near me in Europe. And can't. Even MacDonald's signs you can get to with ladder and they are not that common.
Why would someone do that? Because they didn't have the right size
Alistair Heaton said:Looking at them I suspect they are a modular pick a height and the required number of reducing dia tubes turns up that fit on a lorry trailer and a "sign" crew turns up and mods it to the height required and type that's being installed.
