I am designing a concrete column and would like to design it for axial only. we have enough shear wall to take the lateral load but in reality the column will be cast together with beams and dowel bars and there will be moment at connections. I want to assume pin connection in the model because the column sizes are limited, and in reality the bar will be yield if capacity maxed out and lateral load will be taken by shear wall.I don't know if i need to do a section analysis to ensure concrete crush will not be the failure mode (for moment and axial load in reality case) at the connection.
Thanks for any comments or input.
