harmsgundam
- Dec 16, 2011
- 23
Hi all,
I am new in the design of bridges and I would like to ask for opinions regarding the design of longitudinal beams directly supporting the slab above. Is it fine to subject the longitudinal beam to the full load of an MS18 truck loading/ lane loading for example (i.e. 324kN gross weight). Well not the full gross weight depending on the distance between abutments/ piers, but since a truck loading/ lane loading will cover a 3m lane width, normally there are several longitudinal beams within that 3m span. So should I design 1 longitudinal beam subjecting it to the full truck/ lane loading or will the load be shared with the adjacent longitudinal beams? Thanks in advance for those who can response.
