VVang
- Jan 30, 2024
- 6
Hello, does anyone have tips or advice on how to design a concrete structure that will be underwater? A contractor provided a 12" thick structure with #4 at 16 o/c (I don't think #4 at 16o/c for a 12" slab meets the minimum required steel). I need to verify that this will work but I have never done concrete analysis for a structure underwater and would like some tips or guidance. Can I have water load applied on both sides of the concrete for my analysis, essentially canceling any moment loads since they will be the same on both sides of the wall? Would concrete crushing be a more critical aspect instead of steel yielding? Any advice or input will be greatly appreciated, thank you.
