Hello all,
I am currently working on a Pin Base model that is utilizing a design table to modify and create different configurations. My current model is of a 4 x 4 array with pin holes and pins. No problem. I can input the pitch, array size, locations, and pin dia in one excel "Input" sheet. All calculations for X and Y locations are done for me and automaticaly copies to the Solid works "Design Table" sheet (pretty cool). My predicament is; now that I've figured out how to control each individual feature (suppresion, dims, etc.), Iv'e run into a brick wall. The above mentioned model is only a 4 x 4 test platform. I need to do the same with a 41 x 41 model. To do this I must have close to 15,000 collumns. As you all know, the Excel spread sheet can only support up to 256 collumns (scrolling to R.H. side, not down), it ends at collumn "IV". I would like to know if anyone out there knows how to add collumn cells to the spread sheet or how to link sheets that Solid Works will recognize as part of the same sheet? Another angle might be to change the way solid works references data in the excel spread sheet. I.E. instead of referencing cells for one configuration left to right, changing the setting to reference cells top to bottom. Don't know if this is possible. Can anyone help me with this. Basically, I need a way to access more column cells to be able to support 15000 features in the same model. I don't want multiple models, only one.
There is a user in here by the name of cknull that explains he is handling 4000 dimensions in one excel spread sheet. Obviously he has found a way to change more than 256 features in the same model. does anyone know how to contact him through this site? I do not see a function where I can present him with this question directly.
