mapleleafs
- May 17, 2004
- 2
Has anyone experienced dezincification of pump impellers? We started our water treatment plant 5 years ago and now have to replace all our impellers on our vertical turbine pumps. The original material of the impellers is a brass alloy 875 (15 % Zinc)and the manufacturer is now recommending a tin alloy 903. We are also trying to find out why this happened. Are water at the time of startup was ph 6.8 , chlorine free 1.0 mg/l and an alkalinity of 10 mg/l. It appears the damage was done in the first two years of operation as we lost 12 % flow. We started using a zinc pyrophosphate for corrosion control after 2 years and pump production seemed to stay the same as if the damage stoppewd occurring. We did coat two impellers on one of are small pumps with Belzona last year instead of replacing the impellers but the larger pump impellers are not worth trying to save. Any comments would be appreciated.
