Disable Warning Messages while opening assy's
Cadillacman
Aerospace
Nov 12, 2013
11
In NX7.5 when I open an assy, sometimes multiple Warning Messages appear stating that a certain file is Modified or Read-Only, etc. When the Warning Message appears the assy stops loading until the message is addressed and of course, my only option is OK. How can I disable those messages from appearing and stopping the loading of the assy?
Do you have your assembly load options set to partial loading?
DidierPSICAD, Even with "Cancel Load on Failure" I still get messages saying that some read-only files have been modified. Thanks for your suggestion.
SDETERS, the 'Partial Loading' is defaulted and the messages boxes still appear. Thanks for the suggestion.
There has to be a way to disable the message boxes. Even if the message box displayed some info with is cataclysmic, I am not given the chance to abort or stop or cancel, all I can do is choose OK.
File -> Utilities -> Customer defaults -> Assemblies -> General -> Miscellaneous
In this dialog there are a few "Display message when..." options that might do the trick.
www.nxjournaling.com
