Electricpete: just Googled some info on the overall energy utilization efficiency of thermal power plants:
"Note also that we have confirmed that the net thermal efficiency of the coal burning electric power generating plants is just under 30%. Actually, there are many additional losses in getting that electricity to distant homes, and the net electricity actually received at our electrical outlets is only around 13% of the original energy in the fuel! Sad, huh? (most of that additional 17% of energy loss is due to the long high-tension electrical lines that carry the electricity the many miles from where a power plant is to where you are. Since those wires carry very high electrical currents, and they have unavoidable electrical resistance, there is an unavoidable power loss of I2R. Essentially, all those long power lines act much like the wires in your toaster do, to get hot and radiate away heat. Conventional design of such high-tension lines is such that they INTEND that only 90% of the electricity put in one end of a 60-mile long high-tension line actually comes out the other end, and all the rest goes into heating the atmosphere around the wires!)"
from this link:
Also here is a link to European average thermal plant to gross electricty output at the plant:
Generally it looks like the realistic average efficiency of a thermal electrcial plant is about 30-35% at the point the electricty hits the high tension lines, then start subtracting transmission and voltage conversion losses down to the 115 volts you use in your house, and the generally accepted figure is that about 10% to 15% of the energy burned at a thermal generating plant comes out your plug at home, and then you lose even more due to the inefficiencies of the appliances using the power.
Thats why I like to argue with the geo-exchange heat pump zealots about how much more "efficient" they are. It all has to be taken in context. Geo-exchange heat pumps used in an area with relatively "green" electricty from hydro or nuclear IS a good thing, but the geo and heat pump systems are actually causing more pollution in a coal fired thermal plant zone, compared to burning the fossil fuel at a higher, more efficient level at the terminal end (your house).
