Elastomer AV mounts
fluff
7
0
0
Hi, i really need some input on:
What is the current state of the art for elastomeric mounts over the full -55 to +80 deg (ish) temp range - resonant frequency stability and damping? What suppliers are the leaders in this field?
The mounts are to be used to support an optical bench under broadband ecitation and farily high G loads (10 g maximum aprox)
Thanks in advance
John
Think i need to clarify thing a little! The term optical bench may not have been correct... The bench i refered to is ptobably better described as a isolated (by the required av mounts) bed within a airbourne electro-optical system.
