Green 123
Aerospace
- Feb 19, 2024
- 56
What is engine shock loading? how does it differ from hard landing?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Would you mind explaining all reasonable interpretations of "engine shock loading"?thermal shock?
dropping the engine on the ground when trying to install shock?
if you are going to ask questions you need to provide a LOT more info and context for them.
Would you mind explaining all reasonable interpretations of "engine shock loading"?Birds flying into the engine / propellor?
Blades / (fan or props) falling off
Sudden full power / blade angle change?
In connection with AMM chapter 05, namely "special inspections of engine"OP - maybe you should start by explaining why you are asking this question and in what context are you seeing "shock loading" referred to. its a rather vague question.
This statement is so deliberately obscure... Green123... I believe You are playing guessing games with us REAL professionals... and I am about to report this posting of yours as non-professional.In connection with AMM chapter 05, namely "special inspections of engine"
