Excel (2010) table comparison and list generation 1
DaveJFT
Automotive
Dec 5, 2012
60
Hi folks,
I'm wondering whether someone with a vastly better knowledge of Excel 2010 than me would be able to help me?
I have a table of parts (washers) of varying dimensions and I'm trying to find groups of parts that have sets of dimensions that are equal or smaller in every dimension (see the .xlsx spreadsheet attached) and generate lists of those parts. What I'd like to make Excel do is to take the header of each list, i.e. the part name, search for it in the first column of the table then, when found, compare each of its dimensions to the same dimension in each of the other parts, building up a list of part names that are smaller in every dimension than the subject part. If any part is larger in any dimension that part is disregarded.
I've been playing with VLOOKUP (to search for the part), IF and AND functions but not managed to successfully do what I need.
Would someone be able to give me formula that will do the comparison and build the lists?
Many thanks in advance!
Dave
 http://files.engineering.com/getfile.aspx?folder=017a308d-6308-446e-89ee-30fc8f4231c6&file=Washer_comparison.xlsx
The following is a macro that will do what you want:
Code:
Sub washer()
Dim iRow1 As Integer, iRow2 As Integer, i As Integer, j As Integer, hits As Integer
Dim source(8)
iRow1 = 2
iRow2 = 2
Do Until IsEmpty(Cells(iRow1, 1))
    For i = 0 To 8
        source(i) = Cells(iRow1, i + 1)
    Next i
    Cells(23, iRow1 - 1) = source(0)
    hits = 1
    Do Until IsEmpty(Cells(iRow2, 1))
        If iRow1 <> iRow2 Then
            test = 0
            For j = 1 To 8
                If Cells(iRow2, j + 1) <= source(j) Then test = test + 1
            Next j
            If test = 8 Then
                Cells(23 + hits, iRow1 - 1) = Cells(iRow2, 1)
                hits = hits + 1
            End If
        End If
        iRow2 = iRow2 + 1
    Loop
    iRow2 = 2
    iRow1 = iRow1 + 1
Loop
End Sub
Wow, thank you zelgar! I've reached the end of my day now so I'll try to apply it on Monday - I've never worked with Macro's before so this will be a different challenge.
Fantastic! It works a treat - once I'd stumbled across the right drop down at the top of the code window to apply it to the button rather than General ;)
