Excel Add Qty for Unique Parts?
mfleming
64
Hello.
I'm combine unique names and add the quantities. I use data extraction in AutoCAD to excel and I get all my Parts and qtys.
Column-A = Parts Name
Column-B = Qty for Parts in Column A
Column-C = Parts Name
Column-D = Qty for Parts in Column C
Column-E = Parts Name
Column-F = Qty for Parts in Column E
.... ect up to Column V
See Image:
Basically I want each unique part and its quantity.
I tried using a lookup but I haven't really used it very much and can't get it to work properly.
Any Suggestions?
You'll probably want to look into a Pivot Table. Dependent on what you want to do, you may have to rearrange your list into two columns (Part and Quantity) before you set up the pivot table.
Cheers,
Joerd
The function SUMIF will get you going.
Thanks I'll look into Pivot Tables.
I tried the sumif function but I couldn't get a good way to cycle through all the data when its not in just two columns.
