msucog
- Feb 7, 2007
- 1,044
anyone happen to know a good way to count the number of points within a given area? let's say you have a map of the u.s. and there are 10 areas identified with some overlap. there's say 100 points spread out through all the areas and i want to count how many points fall in each area. you're given the lat and lon of each point and know the lat and lon of the intersection of each line that create each area. the areas are oddball shapes (not simple squares) with up to 8 or 10 sides.
the only way i can think of is to have several if statements to evaluate if each point lies below the upper line, left of the right side, above the bottom line, etc. then count if all cells return "true" or "yes" or whatever the output is for each if statement. the problem i see is that due to the oddball shapes, the point may not be left of a particular line on the right side since it's technically below it. for example the "." are inside the area, the "X" is the point, and the other is the right side of the area.
............X.\
__________\
any suggestions?
............X.\
__________\
any suggestions?
