I've spent the last two days with an END HOME problem - it alway goes to EA358. The column EA1 contains the text 'lastcell', but there's nothing below row 8. I've even moved 'lastcell' to BA1 and cleared the contents, then deleted all the rows between 8 and 500. END Home still goes to EA358. I can't find any page breaks in that area either. If I enter something into a cell below line 358, END HOME moves down there. If I clear the cell, END HOME still stays there. Could default cell formatting cause END HOME to fail? A new sheet seems to work okay. Any Ideas?
I've been trying to use END HOME to find the bottom of the used area of the sheet so I can make the print range A8:R(bottom row, wherever that may be). The END HOME problem is messing that up. Any thought, or suggestions are welcome. Can't tear my hair out - don't have any.
